Bxepanded skid plate question
Shootstraight
BX2200
Aug 23, 2017
9
Kennedyville, MD
Hi gang. Pretty much a novice overall on all things tractor but I ordered and installed a bxpanded skid plate for my bx2200. It hitches to the MMM hydraulics- and you need to keep them "up" all the time. But my MMM hydraulics and 3pt are all connected. So I can't use any attachments with the the skid plate on? Is there a way to Jeri-rig the plate up so you can still lower the rear? In other words could I wire Up the skid plate (and the MMM hydraulic arms up) so i can move the 3pt up and down?
thanks!
brett
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
525
535
Amsterdam, NY
Turn the mower height adjustment knob to the "Top" or highest positions. Do this whenever you are operating without the deck. It will keep the lower arms raised and allow you to raise and lower the 3 PT as needed.
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
169
76
Danville
thanks!
brett
I don't use a MMM but my understanding is that you don't use and or need the skid plate when the MMM is attached. I have the skid plate on full time as I do not use the MMM.
William1
BX25D
Jul 28, 2015
1,312
505
Richmond, Virginia
One thing I found about the skid plate. The spacers I got when I bought my plate were little more than cut-offs from some conduit and very flimsy. I went to my local H-D/Lowes and got robust steel spacers of the same OD that were actually the same ID as the bolts. Much better.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
70
58
Lakes Region, NH
It is not possible to have the skid plate and MMM on at the same time. It is one or the other since they both attach at the same points.
Bee-Positive has provided the way to use the three point lift independent from the MMM lift.
