BX2750 Snowblower Shoes
4,803
Which direction do the shoes get mounted? I have seen pictures of them pointing toward the rear of the tractor, and others, where the shoes are pointed forward, and are under the snowblower. What is the correct orientation? thanks
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,228
1,012
Williamstown Ontario Canada
Consider the purpose of the shoes. They are intended to help keep the cutting edge of the blower above soft surfaces like unfrozen gravel or ground.
Think of them like skis. They need to support the weight of the blower and to do so need to be centered at the balance point.
Install them so when you are blowing snow, they are trying to ride up on top of the surface you are blowing.
Dave
conropl
L3560 HSDC
Oct 17, 2016
233
West Michigan
Like this. The leading edge is bent up to allow it to ride up, and this way it is closer to the cutting edge... which is better. The closer to the cutting edge the better.
Sent from my SM-J737V using Tapatalk
