Bx2660 fluid change
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
359
143
St. Louis, mo.
First transmission fluid change on my bx2660 . Anything to do special or is it drain and refill, and check screen for filings? Thanks
3,051
change engine oil too?- and I would recommend Rotella T6 for diesels
Filter via Kubota
Drain plug on tranny - then pull the screen - I will tell you - if you pull the screen WHILE draining.......flo will be mo! ;):) Again - I would place S-Udt2 in there too.
How many hours? Ought to change fluid in front end too!
5,510
YES YES as Brother Hokie said,, and dont forget to clean the screen too,if yours is like mine I found some stuff in the filter, AND DONT LOOSE THE LITTLE PARTS..dont ask
And refill with Super Udt2, you will notice a difference in the whine on the BX,shhhhh it gets quieter....
I use M1 Diesel oil , but use what ever color you like as long as it meets the specs. But there are guys that swear by Amsoil
And while your down its a good time to grease everything up and you might as well drain the front end and refill with SUDT2. Grease the fittings onthe mower deck check the belt and sharpen the blades,, a fun week end :)
Steve67
Jan 20, 2017
359
143
St. Louis, mo.
At 242 hrs did the transmission and engine oil change today all went well. Still need to do the front axle
