Well, my tractor sat quite a while, as I've been mostly out of state for quite a while. My son went to use it, and the throttle lever would not budge. Bummer.
I am home, so I dug into it today. Found it's a pretty simple mechanism. Loosened it up, cleaned it up, and put it back together. Fiddled with the tension to get it where I wanted it. Then spent about an hour doing some actual work on it! That felt good!
But is there a recommended procedure for setting the tension? Or is it just, fiddle with it until it's good?
I used some Seafoam penetrating oil to get things loosened up, but is there a factory lube recommendation?
