Bx25
John075
Chester,nj
Hi to all
Here is my question. I have a bx25 and I may get a GMC 3500 mason dump will the bx25 be able to load the dump. I will remove the wood in the gussets to gain access if I need too.
Thanks
John
P.S.
I do understand I could always build some sort of ramp to climb, but I rather not do that every time I load spoil
3,582
It might make if if you dont have sideboards out the wazoo on it
Loader:
Loader type: Kubota LA240
Height (to pin): 71.3 inches [181 cm]
Dump clearance: 52.4 inches [133 cm]
Dump reach: 26.2 inches [66 cm]
Dump angle: 45
Rollback angle: 29
Breakout force (bucket): 992 lbs [449 kg]
Lift to full height (at pin): 745 lbs [337 kg]
Lift to full height (at 500mm): 518 lbs [234 kg]
Bucket width: 48 inches [121 cm]
John075
Chester,nj
Thanks Skeets
Yeah, not having the dump right here so I could measure makes it a little bit of a challenge.
I was planning on taking the boards out if I had to too. The other thought that I had was if need be I could always make a temporary ramp. I do believe though that it may even work with one low board after all it is a GMC typically lower than Fords of the same size.
Thanks
John
dusty-t
974
Mountforest Ontario
I have a B8200 , I don't know just how close in size it is to yours, Gmc one ton dually 4x4 with 8x10 flat deck (no dump) with 2ft fold down sides. I can only get about a half load on the truck with the sides down. Now that is loading gravel or topsoil, with something lighter like mulch, you could push it higher.:D Dusty
