I have a BX25 and had to order a replacement instrument gauge cluster. The original had mechanical Temp and Fuel with LED hours and RPM. upon pick up from dealer was informed can no longer get the original and received an updated replacement. came with an adapter cable and no directions but was able to hook up. The RPM is now mechanical and the rest digital. The RPM gauge does not operate nor the Hours. All others function. I emailed Kubota and the reply was to contact the dealership. I spoke to 3 facilities and no one has an answer. Anyone run into this and what was the solution
Thanks
Thanks
