BX2412 Loader 3rd function with BX2821A Snowblower Chute diverter
tjstractor
BX 2680
Dec 17, 2019
24
Great White North
My BX2680 has the Kubota 3rd function kit for the loader, part #BX2412. The 3rd function diverter valve is on the loader so when I remove the loader for the snowblower it isn't available to use to plumb in hydraulic snowblower chute flapper controls on my 55" BX2822A Blower.
I'm looking to install the BX2821A hydraulic divertor option on to my snowblower but would prefer to just use the joystick controls and wiring already on the tractor from the loader 3rd function (BX2412) rather than running the additional wiring and switch that comes with the chute diverter kit for the snowblower (BX2821A). I'm assuming I should just be able to plug in the electrical connection and it should work (maybe the connector needs to change)?
Does anyone use this setup on their machine. I've seen a couple of Messicks videos this way but not sure exactly how they combined the 2 kits. I'd like to firm this up before I spend the big money on the BX2821A kit.
BX2412 loader 3rd function diverter
BX2821A Snowblower chute flapper 3rd function diverter
5,775
I am confused. Where is the third function valve? I would not exoect it to be a "diverter" Post a picture of it.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
460
446
Amsterdam, NY
I'm confused, which seems to be getting more and more normal these days.
My line of thinking:
The blower is powered by the mid PTO.
The same lines that raise and lower the FEL would be used to raise and lower the snow blower.
The lines that dump and curl the bucket would be used to pivot the blower chute.
You would just need to be sure that the lines from the blower are long enough to reach the connections on the tractor. No 3rd function is needed, unless the snow blower is NOT powered by the mid PTO.
tjstractor
BX 2680
Dec 17, 2019
24
Great White North
Hey Guys thanks for reading my long post.
This is to run the chute deflector up and down with a hydraulic cylinder on a BX2822A snowblower (all current BX snowblowers). The kit for this is BX2821A. It has all the parts including the 3rd function diverter valve that mounts on the snowblower housing.
The issue is it is wired differently at the tractor than the BX loader 3rd function diverter that is part number BX2412 ( I already have this on my tractor). I'm wanting to combine the wiring portion of these two kits so I only have one 3rd function diverter switch in the cab / on the hydraulic control stick.
5,775
If your loader valbe already has a third functiin why do you need that diverter and harness at all? All you need is the cylinder on the chute.
tjstractor
BX 2680
Dec 17, 2019
24
Great White North
The BX2412 kit that is the OEM 3rd function for the LA344 loader puts the diverter valve (not true 3rd function) on the actual loader (3rd picture in my original post behind the plate that says "no step") so it is gone in the winter when the loader is removed. All that is left on the tractor is the switch on the control stick and wiring harness / relay / connector that activates it.
5,775
OK. I get the brain dead diverter setup.
Thats one of three sets of outlets. Where are the other two and what are they used for when the blower is mounted?
Mikeymotorbikey
B2601, Case 446, JD4475
Jun 30, 2022
North Branch, Minnesota
So, his first function is probably blower lift and lower. Second would be chute rotation left and right. For the deflector up and down he will require a third function. His current third function/diverter goes away when he removes his loader. So it should be just an electrical connection that gets broken when the loader is removed.
You should just be able to tap into this connection to power the new diverter for the deflector.
5,775
In that case seems as simple as cutting the connector off the chute harness and replacing with one that matches the 3rd function.
tjstractor
BX 2680
Dec 17, 2019
24
Great White North
Yes this is what I need to do. I was wondering if anyone here had done that as I've seen pictures of similar setups. It's an expensive kit to buy if it turns out it isn't this easy.
5,775
Have you considered scrapping the diverters all together and putting a real 3rd function valve on the loader?
