Hello,
I recently purchased a 2019 BX23S with the PTO not working. I did some "internet research" and found a couple of common issues that might be the problem, it wasn't.
The problem I am having is the mid mount and rear mount PTO does not work at all. I don't even get the faintest movement from either PTO when trying to engage it with the lever.
I changed the hydro fluid, filter and cleaned the screen when I first got it. The screen had some red fiber looking stuff ( I kept it on some blue shop rags) that looks like either filter material or red shop rag material. I have cleaned the PTO valve that is semi hidden behind the frame plate that the lever connects to, blew shop air through it and it is clean and free. The screen was pulled a second time after about 10 hours of use and no RTV or red fiber material is present, it is clean and clear. When I engage the PTO lever and am not sitting in the seat it shuts the unit off, so I think the safety switch for the lever and seat are functioning as expected.
I am currently waiting on the WSM to arrive so I can further troubleshoot this. The unit drives and FEL and BH work very well, just would like to have the MM PTO and Rear PTO working.
Any ideas? Thanks for any input and assistance.
