Why you looking to space out the front end? It really will not help stability since the front end pivots on a central pivot.I'm curious. I can't seem to find any info. Are there hub-centric wheel spacers made for the front wheels of a BX23S?
Links are appreciated.
I knew this type of response would come..lol.Why you looking to space out the front end? It really will not help stability since the front end pivots on a central pivot.
I'm aware the front axle is on a pivot, and of the negative sides of spacers up there. I'm brainstorming ideas.
I'm looking for 3/8" or 1/2" hub-centric, with the lip that protrudes through the center hole of the wheel.
Practice what you preach there, Bucko.
No real projects for the tractor im guessing so tractor sits in garage getting customizations? This is what OTT does to folks! Hehehe!Why space out the fronts? Garden rows?
Pretty rude response to give someone who gave you information to help you. You obviously don’t really want help if you are going to be rude to people answering your questions.Practice what you preach there, Bucko.
Nope
When it arrived mid August I was in a frenzy to get things done. I felt overwhelmed. Before I knew it, I had everything on my list finished, where prior to not having the tractor, I was almost desperate for help. Not once did it tell me "I'm busy" or complain.No real projects for the tractor im guessing so tractor sits in garage getting customizations? This is what OTT does to folks! Hehehe!
Pardon me? The comment was not quoted for your response, to be polite.Pretty rude response to give someone who gave you information to help you. You obviously don’t really want help if you are going to be rude to people answering your questions.
You noticed I avoided that? In due time.I don't think you answered someone's question when asked why you need the spacers on the front to begin with.
Looks like prices that are comparable to what I paid in the past for my BX rear spacers and also as a house warming present for my son in law's BX23S...If you found something there that works I expect you will be pleased with the quality for small tractor use.To further elaborate on my in-depth hunt for hub-centric front wheel spacers, I not only found some, I found them with the centerbore lip in very thin, to very thick at reasonable prices.
CustomMadeOnly - Browse all you're wheel spacer needs.
On my BX23s, there is a raised face machined to which the wheels-bore centers too the axle/spindle. The conical of the stud hole and the conical acorn nuts further strengthen that.I don't consider the front wheels of my BX23S to be 'hub centric' as the bolts are tapered,whereas the nuts on my F150 are flat faced and have washers.
