sorry, the brake is really a set of 'friction discs' that when you press on the brake peddle, they 'squish together' to stop rotation of a shaft connected to the differential. When lever 010 is pulled forward, 060 plates get pressed and 'brakes' are applied.The case shown , is the right side of the 'differential', right axle goes through under 010...
