BX23S blowing 5 amp fuel pump fuse
brants51
BX23S
Mar 15, 2026
10
TN
Good evening,
My tractor recently died because of what appears to be a blown 5 amp fuel pump fuse. It has plenty of diesel fuel, the filter is new, not clogged and it appears all safety switches are physically closed. I replaced it and the again the fuse blew after cranking it over.
1. Could it be the pto or hst safety switch? (Nope, fuel on own circuit)
2. Fuel pump bad?
2. BX23s wiring diagram?
Any suggestions appreciated. Thanks
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,149
1,067
Amsterdam, NY
Electrical diagram here BX23S WSM
What year and how many hours on the tractor?
Bad fuel pump or fuel pump connections...maybe?
brants51
BX23S
Mar 15, 2026
10
TN
2020, 475 hours, fuel pump connection looked fine. I'm planning to check continuity/voltage today or tomorrow
BX23-S,57 A-C D-14,
6,321
That 5 amp fuse and fuel pump are connected to the alternator using the red/yel wire.( IG termianal )
Not too sure why....
FYI... if you have a full tank of fuel , you can run the tractor without the fuel pump. have no idea how long I ran mine for, but noticed the connector had unplugged itself !
brants51
BX23S
Mar 15, 2026
10
TN
When I pulled the fuel line off of the exit side of the pump, nothing came out? I'm around 1/4 tank
Bee-Positive
Nov 16, 2022
1,149
1,067
Amsterdam, NY
I assume you replaced BOTH fuel filters, before and after the pump.
Loosen the fuel cap and pull the inlet side off the fuel pump, see if you're getting fuel from the tank to the pump. Have a bucket and rag handy. If little or no fuel, then filter or tank outlet is clogged and maybe the pump is running dry, it might overheat and blow a fuse.
If getting fuel to the pump reconnect the inlet and take the outlet hose off, direct the outlet of the pump into a bucket with a short piece of hose. With a good fuse installed turn the key on without starting, you should hear the pump run and see fuel going into he bucket. If not, bad pump or bad connection.
brants51
BX23S
Mar 15, 2026
10
TN
Both filters are new. The filter (less than 12") before the pump inlet appears to be full of diesel, but I have not checked right at the inlet yet, but I will tomorrow. Thanks
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
The fuel pump has it's own fuse. So it is either the fuel pump faulty or the wire from the fuse (red arrow) shorting to ground.
Measure the fuel pump current by connecting the two probes of an ampmeter into the fuse socket.
Check this wire for chafe. Sorry about the poor scan quality, it is from kubotabooks.com WSM. Maybe you have a better quality scan where you can read the cable colour.
brants51
BX23S
Mar 15, 2026
10
TN
Will do! I'm planning to try and troubleshoot today. Image was good enough, I downloaded the workshop manual for wire colors.
brants51
BX23S
Mar 15, 2026
10
TN
Update:
1. Confirmed the fuel pump inlet is getting fuel
2. Measured incoming voltage, 12.4v (section 4.7.1 in manual)
3. The fuel pump measured OL/ no conductivity (section 4.7.2 manual)
This leads me to believe the pump is bad. Calling local dealer.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
An open fuel pump does not fry fuses unless it died together with the last fuse.
As far as I can see the pump is electronically controlled, so measuring with an ohmmeter may lead to high impedance / open circuit.
BX23-S,57 A-C D-14,
6,321
I ran on in my dieselled forklift for 10+ years. Others ,here, have been using them.
I've used one to filter old fuel for 5 years....
probably cheaper than the tax or shipping for the OEM one, so well worth the 'expense'.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,388
1,009
Minnesota
Is this normal for a fuel pump to die out with this low of hours? Starting to get nervous about my 1880 with all the issues folks are having with the BX line of tractors. I only have 250 hours on mine.
