BX2370 starting issues
Bob KY
BX2370
Apr 29, 2025
Kentucky
Thought it was my main switch, so I replaced that and it didn't help. Tractor turns on, glow plug lights, but when I turn to engage starter, everything dies.
What could be the problem?
5,552
bad battery
bad ground
bad battery cables
you have enough current to light the lights(2-3 amps) but not enough to spin the starter(100+amps)
2,744
The battery is good. I've checked it and it has a full charge
Not to jump to a crazy conclusion - but a fully charged battery can only be called a fully charged if you do a load test on it.
I cannot begin to tell you how many batteries I have had that showed 12.6 but could not provide the amps to start.
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
255
138
Agua Dulce, California
so true, for a simple test he might just want to put the voltmeter on the batter and watch the voltage as he cranks it over. let us know what the reading goes down to. On the other hand it could be good and have bad connections or cables. good luck
2,744
As all of us have mentioned - take all cables off, clean with light sanding, bright. Then place back on and snug tight. SEE IF this makes any difference.
