BX2370 pto selector
bigmoose
BX 2370
Mar 18, 2018
Plymouth, Vermont
Hi all!! I'm new to the tractor world - just bought a used Kubota BX2370 and am slowly making some headway in figuring it out. It had no manual so I've been viewing YouTubes and relying heavily on online info to get me up to speed. I have a question regarding the pto selector lever (mid/rear/both). When in "rear" or "mid" does it refer to only the pto engagement, or should it affect the hydraulic lifting and lowering as well. On my tractor, regardless of what is selected, both rear and mid implements raise and lower when the hydraulic lever is operated. Thanks!!
07wingnut
258
106
Clearwater, BC, CA
Refers only to the pto. The mid and rear 3pth raise and lower together, however, if the mid hitch is pinned in the up position the rear 3pth can still be raised or lowered by itself.
esloser
working on BX1870-1
Oct 30, 2015
76
Millville, NJ
You can also pin the rear lift arms up so you can operate the mid independently.
1,698
I think there is a plate to attach the lift arm to to hold it up. Plate attaches to ROPS and may be an extra accessory.
