Bx2360 Will Not Start
OhioOrange
BX2360
Sep 6, 2016
I have a 2012 Bx 2360. I just washed it after running it for 5 minutes in the drive. After washing it will not start. It just clicks with no electrical dashboard icons functioning. I checked the battery and it has 12.5 volts. I checked the safety switches etc. but I have not figured out why I can't get it to turn over. Any suggestions?
4,245
OK were you mowing with it? The PTO lever is a PIA if its bumped just a tad ,,shesa a no go,, seat switch maybe,, but i would go with the PTO lever shake it up and down a couple times and try it.. I have that issue with mine
2,863
Do what Skeets said, move all the levers a bit AS you are turning the key.
Let her dry out too - things might change as the water drys. Sometimes the water can get into the ol electrical thing-ma-bobs and cause all kinds of pitas!
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
The dash lights should be coming on even if it was a seat/pto switch. I'd double check those battery connections and chassis ground. The ignition switches are known to argue with water so that would be my next move.
