BX2350 Plastic Fail
RonaldKubota
BX2350
Apr 10, 2019
Holland, MA
Hello, I'm new to this forum. My fender-body structure is cracking and falling apart beneath my seat, sides, etc. I don't want to pay approx. $600 for another plastic assembly. Is there a metal assembly that will fit my 2005, BX2350 without too much adjusting? Also, no dealers in my area will tell me what the plastic is made out of. They all say that Kubota won't tell them. Anyone know? Thanks, Ron
5,511
I don't know of any steel parts that fit it.
The plastic is normally HDPE, it's weldable but not glueable.
Ollie1650
BX23XX
Oct 22, 2020
Atlanta
The BX2350 is the same "Tin" work as the BX2360. The BX2350 parts are not worth buying or fixing.
Go find or purchase the Hood (Bonnet) from a BX2360,BX2370,BX2660, or BX2670 they will all fit. You must use the new mounting bracket that came with the newer hood. Head lights are the same. I had to grind a little on the BX2350's bracket that was on the tractor a bit.
Go find or purchase the Rear fender from a BX2360,BX2370,BX2660, or BX2670 they will all fit. The bolts in the handles may not come out easily. I finally put an impact on them to remove and "JB-welded" new inserts in the holes.
Go find or purchase the Plateform under your feet from a BX2360 or BX2660 they will both fit. The Brake pedal is on the wrong side of the BX2370. Or cut a hole if you find a free or cheap one.
There are 2 little silver brackets that mount to the radiator that keep the metal hood from rubbing on the lower bonnet, I bought those as well.
My BX2350 has a BX2360 plateform, BX24D hood, BX2670 rear fender. Every 5 years the plastic gets brittle and falls off. I got the hood for free because it had a bullet hole in it.
pdubya
BX
Jun 21, 2021
10
Darlington, SC
I see this thread is a couple of years old, and it appears you have replaced most parts from other models, is this also accurate for the BX "underbonnet"? fitting on a BX2350? ( the engine shroud ) Ollie , or anyone else. It seems to be the same part for for the 2360 2370 bx 25, etc. with the part # K2651-54040 . Everything is OK on mine but the under bonnet and I'd like to replace it.
