Bx2350 engine
Sprice930
Bx2350
Oct 19, 2018
NEW JERSEY
I have a BX2350. All has been fine till the other day. It starts no issue while cold but then about a minute later, the engine seems to want to stall, then revs, then seems to want to stall. If inturn off then start again later....same thing happens. Fuel filter? Other issue? Thanks
2,581
def sounds like a clogged filter - or fuel line restriction.
try this first ...
unscrew fuel cap....change?
is fuel level full in tank?
When you turn key? without starting - you here "ticking" ......
3,722
agree with Hokie...get yourself some fuel filters....I believe these BX's still use two of them.
5,248
1,924
Correct. Still 2 filters. One by the engine, other one right under the bottom of the tractor, about under the seat, and if you have a belly mower, it'll have to come off to get to that rear filter.
Lot of guys reinvent the tractor so that filter access is better. I chose not to. Once you've done it a couple times, it's nothing to it.
