BX2350 is a pretty good little machine,
, service items and records. Wonder why the head gasket was replaced...
From the service bill to the previous owner
" " "AT FIELD SERVICE VISIT, IT WAS NOTED THAT OIL RESIDUE WAS PRESENT AROUND RADIATOR CAP AND SLUDGE WAS FOUND UNDER
RADIATOR CAP.
NOTIFIED OWNER THAT TRACTOR WOULD REQUIRE SERVICE IN OUR SHOP DUE TO THE LIKLIHOOD OF A BLOWN HEAD GASKET.
WE WILL ASSESS FOR FURTHER DAMAGE WHEN UNIT IS TORN DOWN.
FIELD SERVICE: Changed engine oil and filter; Replaced air filter; Changed fuel filter; Found water and oil in the radiator
IN SHOP: Removed front end loader and surrounding components to access and replace damaged radiator, head, valves and springs,
head bolts, fuel shut off solenoid and thermostat.
Item K2581-85010-620 COMP RADIATOR 1.0000 151.28 0.00% $151.28
Item 1G962-03046-620 COMP HEAD, CYLINDER 1.0000 794.06 0.00% $794.06
Item 1G822-99354-620 KIT GASKET UPPER 1.0000 146.35 0.00% $146.35
Item 14601-03450-620 BOLT, CYL HEAD (W/HEX NUT
FLANGE) 14.0000 6.71 0.00% $93.94
Item 14601-13240-620 SPRING, VALVE 6.0000 7.60 0.00% $45.60
Item 1G687-13110-620 VALVE, INLET 3.0000 18.31 0.00% $54.93
Item 1G687-13120-620 VALVE, EXHAUST 3.0000 16.82 0.00% $50.46
Item 1E401-73010-620 ASSY THERMOSTAT *** 1.0000 30.29 0.00% $30.29
Item 01754-50612-620 BOLT, FLANGE 7T * 2.0000 2.57 0.00% $5.14 " " "
I couldn't find any verbiage to indicate why it needed all this. Thinking they may have assumed the owner was dumb and wouldn't question the extreme expense!
