BX23 water pump questions
tshep
BX23
Feb 9, 2010
Richmond, VA
So, situation is BX/54 mower runs right up at orange with tall grass.
Recent work shows clear radiator (in and out), minimal internal rust, etc.
I believe I would NOT trust the water pump next.
I got tractor only a few years old.
Is it likely the original pump was a cast or formed (SS?) impeller?
Long term - should I seek OE or other water pump, formed or cast?
8,786
I've said it before, you really need to put the tractor letter designation on after the number
because there is a BX23D and a BX23S completely different tractors.
You have a BX23D
OEM aluminum and ss impeller
Coleman:
Water Pump: 169.79 16251-73073
Gasket: $10.78 16239-73430
Messicks:
Water Pump $212.46 16251-73037
Gasket: $10.94 16239-73430
Aftermarket:
Water Pump and Gasket $39.59
