I was using the BX2230 mower when I disengaged it to pick up some trash someone threw out while driving by my place. When I tried to start the mower again, nothing .... No noise, nothing apparently bent or broken, PTO shaft and U-joints look good so for.
Is there an 'idiot' switch I need to check out? I'm wondering if a seat 'operator present' switch could be causing this issue? The rear PTO runs fine with no noises to suggest something internal is broken. Are there any woodruff keys on the PTO shafts to check?
Other thoughts on what to check?
TIA,
Sid
TIA,
Sid
