My BX2200 starter doesn't operate. There is power from the starter key switch. Heater and ignition lights show. I suspect a safety switch. I have found and checked the one on the high low lever, but can't find the second one. Any guidance please?
start here:My BX2200 starter doesn't operate. There is power from the starter key switch. Heater and ignition lights show. I suspect a safety switch. I have found and checked the one on the high low lever, but can't find the second one. Any guidance please?
PTO must be off, directional pedal must be centered, gear selector must be in neutral. These are the three safety switches on my BX 2200…My BX2200 starter doesn't operate. There is power from the starter key switch. Heater and ignition lights show. I suspect a safety switch. I have found and checked the one on the high low lever, but can't find the second one. Any guidance please?
Thanks found a faulty safety switch on PTO lever.Seat? PTO? Gear FWD/REV? Dead battery? Corroded terminals? Bad fuse? Time to crack open the manual?
Thanks found faulty PTO safety switch.Seat? PTO? Gear FWD/REV? Dead battery? Corroded terminals? Bad fuse? Time to crack open the manual?
Thanks found a faulty PTO safety switch.Seat? PTO? Gear FWD/REV? Dead battery? Corroded terminals? Bad fuse? Time to crack open the manual?
