BX2200 injection pump woes
Brycheiniog
BX2200
Aug 18, 2015
Cambridge, UK
Hi all,
My BX2200 recently developed a low pressure fuel leak between the second and third high pressure outlets on the injection pump. I pulled it apart and replaced the o rings which solved the leak. Unfortunately the 2nd outlet now doesn't pump any fuel :(
I have had it apart again and the plunger seems to be moving ok. Any suggestions what to look at? I haven't dismantled the delivery valve as I don't know if I will be able to get parts..
I may have to bite the bullet and get a specialist to take a look.
Thanks
Jonathan
pvogt38
L3800HST
Sep 7, 2015
Kings Mountain, NC
Jonathan,
Today I discovered that one of the ports on my injection pump (L3800 HST)
is not pumping any fuel. I have no idea what to do next. Did you resolve your issue? Any suggestions?
Thanks,
Paul
King's Mountain, NC
