Dusty Dan
BX2200, Dirt Master Backhoe, Essick VR30RE Road Vibratory Road Roller
The parts diagram shows a 'PIN SPRING', id'd call it a rolled pin, holding the u-joint to the transmission front axle output shaft. My tractor had the propeller shaft flipped and the spring pin was holding the sliding u-joint to the front axle . It sheared and is stuck in the front axle input shaft. Is this 'PIN SPRING' supposed to act as a shear pin?
