I have a BX2200 with a RCK60-22BX belly mower. I noticed some noise when running the deck so I started taking apart the spindles/bearings. The center shaft had a lot of play and a very bad bearing in the holder. After taking the gearbox off, I noticed the output shaft of the gearbox has play, meaning the output shaft can be pushed into the gearbox to the point the pulley rubs on the gearbox housing. Is this normal or is this an indication there is a lot of wear in the gearbox. When I looked at the exploded parts diagrams on the Messicks website, it was not obvious how I could eliminate this play with shims. Since gravity will cause the shift to pull outward from the gearbox when installed, does this play really hurt anything? Thanks for any help.
