BX2200 3-pt & fel stopped working
Erland
Sedro-Woolley, WA USA
For a long while I have had to center the 3-pt manually after selecting to raise the implement. (Also, when raising, it often did not raise all the way.) The other day it stopped holding up and will not lift at all, also affecting the fel so that I could only move it up or down by also activating the bucket. Found water in fluid and changed it twice, with a diesel slosh/bath in between. I blew out the front lines after the last change and the fel went up normally one time and then reverted back to same as before and 3-pt never did come up. The book says to keep the 3-pt down at start-up and wait till it warms up. Did not do this the few times but have tried it since without success.
Anyone have any suggestions as to what to do from here?
Hope I haven't damaged something expensive!
Erland
