New BX22 owner. Got it from a friend, where it sat under a tree for the past three years.
Step #1. Cleaned out the water and crud from the bottom of the fuel tank, installed new fuel filters, and and got it running!
Step #2. It had five leaking hydraulic lines. Four on the FEL, which I have replaced. The fifth was one of the Power Steering lines.
So, I purchased all four lines: Pressure hose from the pump, return hose back to the tank, LH and RH Power Steering hoses.
My question is: the RH line appears to want to go to the left side of the steering cylinder, according to the schematic, and the length of the hose. In the included screen shot it appears the 050 hose goes to the right side of the tractor, even though it is marked as "HOSE HYDRAULIC PS LH".
The item 060 is similarly routed to the left side, but is described as "HOSE HYDRAULIC, PS RH"
Thought I would ask before I mistakenly reversed my steering.
