BX1860 Sputtering when warm
TytanX
BX1860
Feb 7, 2025
Caledon Ontario
Hello,
I have a BX1860 and been having an odd issue where it starts to sputter and eventually die after the tractor has run for 10 minutes or so. For the first 10 minutes or so until its warm the tractor runs normally. I'm in Canada so it's cold right now.
I have replaced the fuel filters and my next step is to change the fuel. I am not hopeful this will help though because it runs fine for the first ten minutes. Any ideas what could be wrong? Seems like a fuel issue to me but i've checked the air filter as well and it seems fine.
I tried taking of the fuel cap to see if there was pressure building up and it didnt make any difference
I've also put a clear line from the last fuel filter to the engine to see if any air was being pulled into the lines. No air was coming from the lines but there seemed to be the tiniest little bit of air coming from the engine side.
Thanks
Bill
