I have a BX1800 that I have been slowly rehabbing. I purchased it "hard to start." After taking apart the head, I found evidence of probable starter fluid use - cracked pistons. At any rate, I replaced the pistons, rings, etc. I have also replaced the fuel pump, all of the fuel filters, oil and oil filter, transmission fluid and filter.
Today, I went to start it, and it would never quite catch. I found that the fuel flows through the filters to the injection pump, but I am getting no fuel to the injector popes or at the injectors. I cracked the injectors thinking that it would bleed the system (although the bleeding procedure for this engine is just running the fuel pump for 30 seconds). At any rate, I get good pulsing fuel up to the injection pump, but nothing from there.
Also, I do see the fuel stop solenoid moving correctly based on whether the tractor is turned on or off.
Any ideas? Should I try to remove the injection pump and inspect it? Is there something that may have frozen in place from disuse?
I would appreciate any thoughts you may have. I am guessing that if it is an injection pump issue that originally caused the hard start, then perhaps they were using starter fluid, which resulted in the engine damages. Just a thought.
