BX1500 Radiator Removal
Steveatusl
BX1500
Jun 16, 2018
17
Littleton, Colorado
I’m having trouble removing the radiator so that I can inspect it for leaks.
I bought the WSM, but it doesn’t help. Are their remove/install instructions available anywhere?
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
Remove the Dynamo, remove surge tank, drain the coolant and remove hoses from radiator. Remove the 4 bolts holding shroud to the radiator and move shroud forward. Remove bolt at top of radiator going thru rubber bushing, the radiator should lift right out. Some have a keeper pin going thru the bottom radiator mounts, need to check before attempting to lift out.
