BX Rear Frame Tie Downs
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
I made up a couple of tie downs for the rear of my BX, since it may have a couple of trips on my utility trailer in the future. I had my local shop cut and bend the plates 45° for me. I wrote 1/4" on the diagram, but somehow they missed that and made them up in 3/8", so there is no chance they'll ever get bent.
I drilled 1" holes for the eyes and 15mm holes on 70mm centers for using the existing rear holes on the BX frame rails. I replaced the original bolts with 14mm X 45mm - 1.5mm grade 8.8 bolts.
I bead blasted the plates, gave them a coat of self etching primer, and then a couple coats of Kubota Dark Gray.
They look like original equipment!
228
IN
Those look amazing, good work. Is "Kubota Dark Gray" something you can actually buy? I guess I haven't looked into tractor specific paints.
SidecarFlip
Banned
554
ROPS grey is available at your dealer.
As an aside, I just attach a clevis shackle to my drawbar and chain down through that. Easy-Peasy.
BX23S-1
540
201
No where Special
Very nice job dlsmith! I might have to steal your idea there... :D
Any plans on a set for the front of the tractor? Looks like 4 of them in your pictures but didnt see pics of a front install.
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
Thanks for the compliments, guys!
Yes, I did make a different set for the front. I put those on a couple of weeks ago. I think I posted pictures in another thread, but I'll post a couple more here.
The extra set are for a friend that has a BX2230 identical to mine, and the serial numbers are only around 100 numbers apart.
Feel free to steal the idea, I didn't patent it.l :D
FYI, the holes in both the front and rear of the frame rails are both on 70mm centers, the front bolts are 10mm, I believe, and the rear ones are 14mm.
Ping
BX2370-1
Dec 25, 2018
311
226
Troy, Ohio
Nice job, the rear ones look like they came from the factory. I didn't notice what grade fasteners you used, but don't cheap out on them. They'll be loaded in tensile-shear when on the trailer.
Thanks for posting
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
Thanks.
The bolts are 8.8 grade, but at 14mm, over 1/2" you could easily pick up the entire tractor by one of the brackets without breaking them. The original bolts had a 7 on the heads, but being an OEM bolt, I'm not sure if that is the grade or if it means something else..
dlsmith
BX2230, LA211
Nov 15, 2018
1,235
789
Goshen, IN
Thanks.
I could only get 14 mm 8.8 grade in the 1.5 pitch at McMaster-Carr. The only pitch 14mm 10.9 grade is available in is 2 mm pitch.
I always recheck torques after using them for a period of time.
