BX Brush hog size??
jay2
139
kington, ohio
I understand, I think, a 4' is best 5' pushing it. (weeds and grass, no small trees, etc,) I have a BX 2670. Anyone using a 5' brush hog on a 2670 or close size?
bcp
BX2360
Apr 20, 2011
645
78
SW WA
I think the manual recommends 42. I have a 48 and wouldn't want any more, both for total weight, and weight distance to the rear. Lifting, backing, and maneuvering is awkward.
If I had flat, open land and could spend almost all the time with the mower down, a 60 might work for me. But then I would probably put another wheel and a tongue on it. :)
Bruce
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
I just picked up a 4' Woods RC4 for my BX25, turns it no problem. I don't think you would have an issue with the 5', but as above I also think it would be too heavy for your tractor. The 4' really is a good fit for our BX's.
TripleR
Sep 16, 2011
1,911
SE Missouri
I use a Land Pride RCR1548 on my BXs and at 425 pounds, I need weights or a FEL when using it on anything but flat land, no way I would try a 5'. Woods, LP and King Kutter make units especially aimed at the SCUT for while they are CAT1 3PH, the geometry is different than on bigger machines with CAT 1.
You will be best served operating within the intended parameters of your tractor and equipment.
