BX 2750-C Snowblower Fan Removal
reamer
B2400, BX1500
Jun 6, 2018
54
Ashford CT
How is the done? Lots of slop at shear pin need to get in there.
How to remove the auger and then get to the fan?
Thanks
200mph
Mar 3, 2017
1,228
61
PA
Need to remove the chain and gear from the back, along with the bearing. Then remove the bearings holders for the auger and the gear box support bracket. The whole "Tee" assembly will pull out the front.
FYI... When I had the fan out I installed a grease fitting to it. It doesn't rotate on the shaft unless shear pin is broke, but the grease prevents the fan from rusting to the shaft.
Good luck.
