BX-2680 Hydraulics loosing lift power
Springer
BX2680 LA344S EA 55" Grapple, Stump Bucket 48 Box grader, Disc Harrow
Jul 21, 2021
97
54
Tiger, GA
BX-2680 2021 70 hours
My Kubota hydraulics is getting wimpy. I can barely lift the front wheels off the ground when I curl. I used to be able to lift them up and slide the mower under the wheels.
I recently changed out the fuel pump and filters. In the early Spring I had a service tech change out the hydraulic fluid and hydraulic filters. A couple of weeks ago, I noticed the lift pressure low. I have to run the RPM up to just lift the empty bucket.
The level is good and the fluid looks okay. It was a bit foamy but no more than usual. I know there is an internal recirc relief that regulates pressure but I have never messed with it. Where do I start?
5,040
Start by using a 3000 PSI hydraulic pressure gauge to measure the pressure coming to the loader valve.
Springer
Jul 21, 2021
97
54
Tiger, GA
Can you point me in the right direction. Where to purchase a guage and where to tap in?
5,040
Here i a a gauge -:there are plenty of other sources. Get a quick coupler to match the ones on the loader and use it to plug the gauge into one of the loader ports to measure pressure.
