BX 2680 fuel intake blocked
Kasimmon
BX 2680
Feb 12, 2022
Atlanta
I've been wrestling with this one on and off for roughly a year. Something in my tank is causing reduced to nonexistent fuel flow to the first fuel filter (which I upgraded using an aftermarket kit to make it more accessible/increase capacity). Slow/no fuel, tractor loses power, sputters and dies.
If I remove the fuel line at the first fuel filter and blow air in, I can get good fuel flow for a few minutes. All our fuel gets filtered through an additional filter funnel on its way into the tank.
I took it to our local dealer in March of 2021 and asked them to check the fuel intake for rust and fuel tank for debris, as well as fix a leak I'd put in the fuel line while trying to get enough fuel flow to load the tractor and head for the dealer. They tried to claim the entire problem was the fuel line leak. When I pitched a fit, the mechanic's notes miraculously included "swept debris out of tank." 🙄
I brought it back to the farm, where it ran great for 5 months... Just long enough for the dealer to claim it must be a new issue.
Since then I've put an endoscope down the tank, used a shop vac to try to suction clean, put in a diesel fuel tank cleaner and tried several blind swipes with long brushes.
I'm at the point where I think the next step is taking the tank off, but looking at those directions I can't help but think it might be just as easy to find a second fuel tank that could sit behind the seat and bypass Kubota's design disaster entirely. At the very least, I'd have a tank that would be easy to service if problems arise in the future.
How stupid is this idea?
1,698
Is the existing tank plastic or metal?
If metal you can use an epoxy lining to coat the inside of the tank.
No idea if you’re able to get a similar product for plastic.
If interested in my repair of rusted metal tank see:
5,521
Had a similar...cough,cough, choke, cough...whew..got her home problem
Took me 1/2 day to properly clean the tank and got a sliver of black plastic out of the spigot(or whatever you call it) that sends fuel from than to the 5/16" fuel line. I looked real hard at first,NEVER saw anything bad..
I 1/4 filled tank with water, sloshed around, drained, blew shop air into it, looked inside with LED light and mirror SEVERAL times(5-6 7??) After i got that 'blocker' out, filled tank with water, let it drain through the spigot, blow it out with air, did that 3-4 times, then sloshed WW fuild in to (alcohol) 2-3 times, more air.OK maybe I went overboard but I KNEW it was cleaner than from the factory. Put it in, been fine ever since...that's about 500hrs of use.
A 'floater' is probably the worst problem to find.... I've since added a filter screen to the filler neck...
Kasimmon
BX 2680
Feb 12, 2022
Atlanta
I'm pretty sure it's a plastic tank, but the BX apparently has a fuel level sensor that can rust. We don't have a covered space for the tractor, and I'm not confident in my ability to get the tank out and back on in a day. Hence my thought of putting a second tank on rather than taking off the seat, fenders and rops to get to a tank with a shape that's next to impossible to see into.
5,521
Might want to call the dealer ! After I went through the 'ordeal', I called, he said 3hrs labour so +-$300 +taxes.
Might be an option....??
WAS BANNED FOR NSFW PICS
5,143
It is a good thing that you don't have a cab on your tractor. The cab takes about 5 hours to remove and then reinstall is my guess. It might also take longer, and I don't know if the deluxe cab can be lifted off in one piece. It took me a couple of hours to take the cloth cab off of my BX22, and I know that the BX23S is going to be a lot more labor to remove and reinstall. I never had a problem with anything in the tank, but I did need to have the 3 point hitch piston worked on. Tractors have become as difficult to work on as modern cars.
