Ok - rather than give a little help - I need it....
Cleaned the ol girl off today, and powerwashed all the grease and dirt off too.
Regreased all the zerks and then said - let me take a look see under the ol girl and check out any sticks that might have taken up shop in the under armor.
Found no sticks - but what I did find - the #$%#$%@ rubber boot that is coming off the main driveshaft looks worse than the tie-rod boots ever did!!!
I got a bad feeling that the whole #$@%@#$#@ shaft needs to be pulled? Much like the lovely fan when broken?????
http://www.messicks.com/part/k2561-14130/cover-joint
Someone in their infinite wisdom tell me that a split boot would work here? AND if so - what are the 2 ID's of said boot? Hub end and the shaft end?
I am amazed that the rubber parts are failing so fast!!! Seems like every "boot" is rotten!
Any help would be appreciated
