BX 23 front tires
Greenhorn
2020 BX23S
Sep 16, 2020
Goshen Ohio
So my BX 23 is in need of new front tires. What’s everyone using as a replacement or is it ideal to use what came stock? Seems to me the stockers wore out fairly quickly (350 hrs)
Scm
BX23S
Sep 28, 2024
158
143
Missouri
My foam filled R4s wore bald in about 100 hours. Although I am working on land that is like 20 grit sandpaper from hell.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
44
36
Lakes Region, NH
The original front turf tires on by BX2370 are approaching 900 hrs with plenty of tread left. Are you spending too much time in four wheel drive making turns on pavement to have that much wear?
Speed25
L2501(sold) - BX25D
Apr 23, 2024
259
374
NC
Go to the dealership sales department (NOT parts department) and have them order you a new pair of front wheels and tires. Sadly it's cheaper to do this than buy/mount the tires by themselves usually. The pair usually runs $160-$200, depending if you're turf, R4, etc.
Greenhorn
2020 BX23S
Sep 16, 2020
Goshen Ohio
I'm almost never on asphalt. Often times gravel. Mostly grass/dirt. There is some tread left but the sidewalls are showing weakness and one of has a leak that is a PITA. I wanted to get it squared away prior to winter.
Greenhorn
2020 BX23S
Sep 16, 2020
Goshen Ohio
That’s great advice. I’ll call them tomorrow
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
201
208
upstate, NY USA
Before you go to the dealership and buy wheels/tires through the Sales Department, (Whole Goods)
look at Amazon.com and compare pricing.
I found R1 AG style there for less than the dealership Whole Foods pricing.
Also with free Prime shipping.
5,731
I'm on my 3rd set of fronts with 1500hrs on the clock , a LOT of pavement time.
There's a KENDA brand K514 ? that should fit, more plies and great weight capacity
NOT available in Canada and I can't order from AmazonUSA and have delivered in USA,which is really, really stupid. OK, IF I play tricks with the computer I can but WHY should I have to ??
WI_Hedgehog
Apr 24, 2024
699
919
Milwaukee, Wisconsin, U.S.A.
The dealer for wheels (tires and rims) is strangely a great option, the same with oil and filters.
The bigger question is what type of tire? There are a few tire threads that explain the differences, and maybe it makes sense to get a complete set for around $820, and perhaps then replace the current worn fronts with new rubber in your free time given you would have a set of winter wheels. I have lawn, industrial, and half a set of agricultural (working on getting the other half). Lawn are great in the lawn though really slick on mossy hills. Industrial are grippy in the lawn but will dimple it (depending) and are a bit slick on wet leaf covered hills. When Kubota ships the fronts and I get my hydraulics completed I'll have a better idea of how grippy the AG tires are.
Greenhorn
2020 BX23S
Sep 16, 2020
Goshen Ohio
I’ll look into the Kendas. I believe this little tractor could benefit from some front tires with more plies. Partially why I’m replacing them.
