Building a 5th wheel bucket hitch.
lc12
68
US
I need to move a 5th wheel camper about 30 feet, on level ground.
And before you ask, no, I do not have a hitch on my truck.
Camper was delivered to farm and not moved for seven years.
Now I am building a shed, and of course the camper is in the way.
So.....
I have a 5th wheel hitch that I bought used.
I am planning on removing the "legs" of the receiver and set on top of two 3" square tube that is framed with 3" x 1/4" angle on the ends.
This will leave me just the 5th wheel plate and frame sitting in the bucket and will be chained in place so that the hitch cannot move.
This will be placed in the bucket of my L4701HST.
I will have my 6 foot brush cutter attached for ballast, and my tires are fluid filled.
The camper will not be moved far, and is on level ground.
Do you all see any problems with this setup?
I have searched on here, and on the net in general and have not found much info.
Those that commented against the idea was never with the use of a 5th wheel hitch receiver being used.
Some just wanted to move the trailer only by placing the kingpin in the bucket.
I know my tractor has the pulling power, and confident that it has the lifting power.
And I am not concerned about my bucket as I have the Ratchet Rake Forestry model attached to the bucket which significantly adds strength to the bucket.
Am I over confident in my thinking?
I just cannot find anyone that will come over for such a short move as my farm is quite some distance from those that I know.
Thank you in advance, and I appreciate all of the information that is provided by this group!
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
6,595
Unless your needing to really maneuver it around you could have just picked it up with the bucket, but your idea sounds fine.
Leave the jacks down and just try and pick it up, if it does it then you should be fine.
When you move it leave the jacks down, just pick it off the ground buy a couple inches, and move slow. ;)
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
my trailer supplier did the following:
made a plate with two holes 1/2 inch welded a pipe to the top of the plate inside diameter of the pipe large enough to contain the connecting piece of the hitch of the trailer
two holes were made in the top of the bucket bolted the component to the bucket and voila drive tractor under the hitch of the trailer lift bucket gently and move the trailer slowly works for me when i need it good for small moves for my horse trailer 5th wheel trailer and hay trailer simple and not very expensive good luck
Bulldog777
L3200, RTA1266, Modern 5' BB, Mustang 60 FM
Jan 25, 2017
215
Buy a used set of pallet forks, attach the 5th wheel hitch to those, you can "un- attach" the fifth wheel hitch and use the forks afterwards.
You can weld a plate to the forks, attach the hitch using the pins that came on it by cutting holes in the plate. Then you resale the hitch later if you want.
Sent from my SM-G955U using Tapatalk
Ramos
1870-1, LA203A, RCK54
Feb 25, 2016
463
Sherman County, Oregon
I move mine all the time with a plate and pipe bolted into the bucket, much like vic mentioned. The open-top pipe is just large enough for the trailer king pin to fit inside. I made my pipe 14" tall so I could make tighter turns without getting the sides of the bucket into the front of the trailer.
Flat plate (3/8"), vertical pipe, four bolts through the bucket. I did add gussets for piece of mind since the taller pipe receives some leverage.
On Edit: My pipe sits almost a foot out from the front edge of the bucket. Again, tight turns. The trailer is 30-32' w/ two slides. Tractor is 60hp with lots of ballast.
lc12
68
US
This is what I came up with.
Timbers are lagged and bolted, forming a frame that will sit in bucket, spreading the weight load, and chained into place.
Hitch is also lagged to timbers.
Chains will wrap around timbers and hitch, preventing any movement
Sent from my SM-G920P using Tapatalk
Oh! And I only have $80 invested in the whole thing.
Probably a bit overkill.
lc12
68
US
Is there anyone in the area that has a hitch and can help?
May be cheaper and easier?
Ray
It is hard to work around everyone's schedule, and I am two hours away, and if they don't show I have wasted a trip.
Easier just to do it myself.
lc12
68
US
An update.
Used my 5th wheel rig to move camper and it worked OK.
Fairly "light" in the rear, but manageable.
The L4702HST had the "oomph" to lift it.
baronetm
L3901HST w/FEL, 3rd fnct. BH77 BH, 5' Bushhog, 6' BBL, 42" Forks, WoodMaxx WM-8H
Apr 19, 2017
122
12
South Central VT.
An update.
Good to hear you moved the RV safely and devised a way to attach the 5th wheel. I would have looked at this issue a little different.
1. Inside a cabinet in the RV there should be a placard that will give you some useful weights, one being the pin or tongue weight.
2. Does this exceed the lifting capacity of your FEL with the 5th wheel attached as close to the pins as possible.
3. How much counter balance do I need? Your brush cutter obviously supplied enough weight and also extends the fulcrum point from the lift point to multiply the weight rating, but being light it was still not enough.
4. Am I traveling over uneven or soft ground that will make my vehicle or load unstable, hence this will be exaggerated by a light counter balance.
Why do I stick my nose in with my two cents, many years of rigging experience and seeing some errors made. I have seen the results of a fellow workers assumptions lifting a $500K piece of new equipment weighing in at 15K lbs. from a trailer, and assuming the fork lift with a weight rating of 20K with 8’ forks would lift and move the equipment with ease. WRONG, due to the width of the equipment and its weight distribution, once the load was clear of the trailer and the operator tried to lower the load it took a nose dive doing hundreds of thousands of dollars in damage to the new equipment and the trailer, also giving the operator whiplash. All subsequent delivery of like equipment we unloaded from the opposite side, proper weight distribution and never having the safety issue again. I have seen the same thing with fork trucks and jib rigs, always worked lifting the same load until the operator used a different jib that extended 12” further, nose dive, the loads fulcrum point exceeded the lift capacity of the fork truck. A short distance of 12” multiplies the load weight X fold. Thanks for listening to my experience.
lc12
68
US
2.Does this exceed the lifting capacity of your FEL with the 5th wheel attached as close to the pins as possible.
3.How much counter balance do I need? Your brush cutter obviously supplied enough weight and also extends the fulcrum point from the lift point to multiply the weight rating, but being light it was still not enough.
4.Am I traveling over uneven or soft ground that will make my vehicle or load unstable, hence this will be exaggerated by a light counter balance.
Good information!
The rear end lifted only because of a stubborn wheel chock.
Once removed, all was OK.
I only moved tbe RV 30 feet on a flat, level, graveled drive.
I used the FEL to raise the RV to remove the tripod support, and then slid the "bucket hitch" onto the pin.
All was good with the world.
Thank you for your concern and knowledge!
