Bucket lift capacity
Bob Simpos
Kubota L295DT tractor with bucket
Mar 16, 2022
Monroe, WA 98272
I have owned a L295DT since 1976. Original stuff including bucket. I have need to add fork lifts to attach to bucket but need to know approximate WEIGHT bucket is capable of liftin no more than 1 foot off the ground. Any thought or website where such information is listed.? Will be lifting 3+ cu ft bags of light weight soil approximately 1800 lbs. Doable?
Oo-v-oO
2000 B7500
Oct 31, 2021
67
56
Central NH
Isn't the loader model the weight in Kilos it can lift? That should get you close.
6,599
Not even knowing the loader # I can safely say Nope, that loader won't lift 1800lbs
Loaders that were available for that tractor were in the 500lb-600lb hundred range
mikester
M59 TLB
Oct 21, 2017
3,601
2,085
www.divergentstuff.ca
I have the same problem with my 1983 honda civic hatchback. It will barely tow my 10,000 lb capacity trailer empty. When I load the trailer with only 3,000 lbs the civic won't tow it. WTF
Lencho
B7100hst
Jan 21, 2017
415
87
NM
Hi Bob, why not just load the 3 cu ft bags of soil into the bucket? You won’t lift the whole pallet at once.
Vigo
B6100, B8200
Jan 9, 2022
595
340
San Antonio Texas
This is a BF300 loader. 300 kilos = 661lbs. That rating is 'to full height'.
I calculated this load to over 1000lbs. That was as high as it would lift it (i did not drive it like that).
So i think your capacity 'to 1ft off the ground' could be as much as double what its 'lift to full height' rating is.
