BT600 hose replacement
jk007
MD, USA
I recently purchased a used BT600 backhoe for my BX and noticed one of the hoses going to dipper cylinder is damaged. Has anyone ever done a replacement of that part and could share some tips. Also, it's not all that clear from the parts diagram what the actual hose part # is.
Thanks
rentthis
1,007
25
38
summerville,sc
Tie a really strong cord to the control end and pull it out through the dipper stick. Take the hose to the local hydraulic shop and have it copied. Tie it to the cord and pull it back through. Be sure to buy the same size hose. A bigger diameter hose might not fit.I use what I have heard referred to as mule tape. It's what electricians use to pull wires through conduit.
