I am currently looking to purchase 60" rotary brush cutter. I have a B3030, and it says that 24" behind the link pins that max weight is 1670#. The cutters vary from about 600# all the way up to 1200# for the same size cutter. I realize the gear box is bigger and and the material in heavier, and that the heavier ones can cut bigger stuff. I guess my question is how heavy of a cutter can I use on my tractor? It would seem that spinning the cutter would not be the problem, the weight would. I have a loader on mine, and just want to buy the stoutest unit I can safely handle without wrecking my tractor in the process. I will be using it to open up some trails on my hunting land through some poplar trees that are up to 3" in diameter. Any real world advice would be helpful.
Mark
Mark
