Still working on my ZD326.
I have some info that might be of use to others working on older zero-turns.
The fenders are plastic. It appears they get brittle with sun exposure. Today I started shimmying my left fuel tank out from under the fender, applying very little pressure, and the fender split. No warning at all. BANG.
On the bright side, the tank is now clean. I plan to take Whitetiger's advice and blow out the lines. They are not easy to get off. I picked up a special set of Lisle hose pliers, but they are wrong for the job. It seems like no decent manufacturer makes a set of normal hose pliers, so it may be time to buy some Pittsburghs.
The right fender is much tougher. I had to wrestle with it quite a bit while working on the control panel. Nothing happened. I guess now I know which side of the mower faced the sun in the past.
My big bargain is not as big as it was to start, but maybe after all this, I can make money as a Kubota mechanic.
Now I will probably buy two fenders. It will be interesting mowing the lawn with the mower like this.
