breaking up large rocks
The_Al
L3540, Heavy duty FEL, 9' bachoe, Brush hog, 72" grappler
Jul 19, 2013
154
MA
Hey Guys,
I have some pretty large rocks that I need to break up before I can even pull them out, so I am looking for some suggestions on breaking them up first.
The girl (tractor) cannot even budge these suckers as they are large and heavy.
I was thinking drill some holes and use a large pole to try and split them in half (although this will take a long time). I would prefer to not have to use any type of blasting.
Any thoughts?
Frank46
L3800 La524 loader
Nov 4, 2013
87
new Iberia,LA
Hey Guys,
Any thoughts?
After the holes are drilled get some feathers and wedges. Stick the wedges in as far as they can go in the hole. Neaxt place the feathers alongside of both sides of the hole. You whack on the wedges while tapping the feathers on both sides. This continually places expanding pressures from both sides of the feathers which are in front and back of the wedges. just keep whacking the wedges and feathers. You will start getting cracks and cracking noises this is what you want too see happening. Or you could just say the heck with it and have your local blaster stick them funny looking sticks with the fuses on them, light the fuses and run like H-ll. Frank
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
After the holes are drilled get some feathers and wedges. Stick the wedges in as far as they can go in the hole. Next place the feathers alongside of both sides of the hole. You whack on the wedges while tapping the feathers on both sides. This continually places expanding pressures from both sides of the feathers which are in front and back of the wedges. just keep whacking the wedges and feathers. You will start getting cracks and cracking noises this is what you want too see happening. Or you could just say the heck with it and have your local blaster stick them funny looking sticks with the fuses on them, light the fuses and run like H-ll. Frank
Forget the wedges and feathers for now. Hell it has been so cold in MA lately, I would just drill the holes and fill them with water every day and see what mother nature will do for you. :D As it warms up later this year (I hope) try the wedges and feathers. :D
The_Al
Jul 19, 2013
154
MA
True, as true can be...
buckaroo52
Kubota L 3800 DT
Jun 5, 2013
102
Molalla, Oregon
My neighbors had three giant boulders in their yard that were about half buried, about the size of a giant refrigerator, that they wanted gone. I just dug holes bigger than the boulders and deeper, right next to them, and shoved them in and buried them...boulders gone !
The_Al
Jul 19, 2013
154
MA
I was going to do this, but this is in my new field for corn and wheat, so they need to go
buckaroo52
Kubota L 3800 DT
Jun 5, 2013
102
Molalla, Oregon
How big are these "rocks" ? The boulders I dug and buried were about. 3 to 4 feet tall and 6 to 7 feet long, and about 4 foot wide. They are 3 feet below the surface, and now have lawn irrigation lines over them. Went pretty quick with my little track hoe. Good luck !
The_Al
Jul 19, 2013
154
MA
They are ~ 12'+ long x 4-6', and they are pretty close to the surface as well. When bottom plowing it is an issue, and the rooting is an issue with this depth as well.
Thanks
