Box Blade Question
Evad
L3301
Apr 2, 2022
55
20
Redmond, WA
Have a 72' BB for my 3301. Can I use it going backwards? I just want to level out gravel going backwards, I am not trying to dig in put a lot of force of it.
Also I noticed that I need my sidearms tighten up quite a bit if I am going backwards so the sidearm doesn't drag against the tire. How tight should I make these? I feel like they should have a little play to slide side-to-side a few inches without hitting the tires, but should I keep them tight?
Thank you!
Bmyers
May 27, 2019
3,598
4,832
Southern Illinois
You can see on my BB that it has a rear cutting blade and can be used when going backwards. I believe that is standard for most BB, but since I haven't seen them all, that is just my guess.
My BB is snug with very little travel left or right.
Elliott in GA
Mar 10, 2021
863
867
North Georgia
Yes - backwards and forwards, most have two blades (front and back on the rear) for that purpose. Going backwards you do not have as much ability to carry material with you, because you do not have the sides to hold the material.
You will have to adjust your side to side motion range with the turnbuckles or pin/slots to avoid tire contact. I use a quick hitch, and that moves everything a little more aft giving the attachment more clearance.
Evad
L3301
Apr 2, 2022
55
20
Redmond, WA
Thanks to both of you. Is it ok to set one arm shorter than the other to tilt it a bit so it moves gravel towards the center of the road?
Bmyers
May 27, 2019
3,598
4,832
Southern Illinois
Yes.
Also you can adjust your top link for cut aggressiveness.
3,384
Keep in mind that a 3PH is designed for pulling, rather than pushing...
I will also use my 3PH for pushing, with a rear blade or box blade. BUT I am not aggressive. Just move light stuff, or maybe snow...
Use the 3PH aggressively in the push direction, and take your chances. My way of looking at it anyway...Actually not sure of what the dangers are...perhaps just the possibility of bending the lower lift arms, or the top link?
