Bought my first tractor - a 1987(?) L2850
Vagabond
1987 L2850 w/ LA650
Dec 17, 2024
11
Maine, USA
I've been on the fence about buying a tractor for years, I actually went to a TYM dealer a couple years ago and picked one out, and told them to call me when they had one... *crickets*
Finally this year I had a big row of white pine next to the house taken down and decided it was time to build a timber frame barn to replace the rotting chicken coop. To that end I needed a way to move big logs/beams around when I was milling/framing them. Thus I now own what I think is a 1987 L2850 with a LA650 loader. Pretty much all the labels are missing, the paint ain't great but I *think* it's in pretty good shape mechanically. Everything seems to work, the engine runs well, there's no major leaks and all the maintenance seems to have been kept up with. I'm told it was a farmer's only tractor in southern Maine and he just wanted something bigger with a cab.
Anyway, I'm mostly a car guy, and have never done anything with a diesel (or hydraulics), so I've been learning a lot. I just did a oil/hydraulic fluid/filter swap today and also (once I finally found the damn thing) swapped the fuel filter.
Beyond that I'm seriously considering converting it to SSQA (I have torches and a welder and have done similar projects before) and eventually adding some more hydraulic circuits for a 3rd function and maybe a rear remote for something. Oh, I also need some kind of seat belt.
Here's some pictures of my beautiful acquisition:
And here's the gumbo I pulled out of the hydraulic system earlier:
2,581
Nice find - but keep an EYE out for that hydraulic GUMBO - looks really bad! I would look to be changing that again very soon. Filter too!
In your neck of the woods - that water in there will cause a LOOTTTT of problems.
If left outside UNCOVERED..... check the gear shift boots and see if they are cracked - if so, replace them!!!!
D.jFarm78
L2250 FEL& L4610FEl, BH, Grapple, Mower, Gannon , blade, disc, plow, rototiller,
Mar 20, 2020
Young, Az USA
D.jFarm78
Mar 20, 2020
Young, Az USA
Nice find
Like old Hokie says keep a eye on that hyd fluid
On my L 4610 I did the SSQA adaptor not to hard. Work Saver is the one I used.
Then welded a plate on the bucket
Got a MTL grapple and a Summit 3rd function I use the heck out of it, clearing brush hauling fire wood ect
Enjoy your Tractor they sure make life easier
Vagabond
1987 L2850 w/ LA650
Dec 17, 2024
11
Maine, USA
I'm not sure I have shifter boots like I've seen on other models, I have forward/reverse and 1-4 gear select on the column, and a high/low range lever to the left of the seat. Are there still boots in there, just hidden?
I'll definitely keep an eye on it now, and probably change it in the spring (or if it clouds up bad again).
