Bought a finish mower, belt routing
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
319
169
Eastern PA, USA
I picked up a new to me 3pt 60" finish mower. It's in perfect condition, completely rust free, belt included, but not on. I was hoping someone had some ideas, because my ideas just aren't working. When I install it on my theorized route, the tension pulley pulls the wrong way. The tension and idler pulley are the wide sides of the V belt, the rest are the thin sides.
ALso, when I hook it up the way I think it goes, it has a bit of slack, to much that I can't take it all up.
The deck:
redmaher
253
US
Before you spend a lot of time and hair pulling make sure you have the right sized belt.
Sent from my LG-H901 using Tapatalk
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Williamstown Ontario Canada
To help me understand your sketch, could you put an X in the three circles which are the blade spindles.
Somehow identify which way the spring is pulling the idler pulley.
If a pulley has a flat surface rather than a Vee we would need to know this as well
My first reaction is that if the big circle is the drive pulley rotated by the gear box, there is not enough wrap of the belt around this pulley in the way you have shown with the red line.
Dave M7040
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Great
They are quite the puzzle some time. They have driven me crazy because if you are doing it under a machine you don't even have a good mental image.
Don't think you will remember the next time or that you can find the paper you prepared, use a paint brush and paint a crude line on the mower marking the belt path and also the belt number while you can still read it on the new belt
Dave M7040
