Biobor
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
125
50
NH
Read in another post about Biobor JF which is good for removing microbial contamination and improved lubricity. Looked into this stuff and saw that there is also a Biobor MD which runs cleaner, cleans injectors, and also does some other stuff, but doesn't remove bacteria.
Which would be better as a fuel maintenance additive? I don't store a lot of fuel, around 25 gallons which may last me 1-3 months depending on tractor usage. I do not have or have not had any fuel issues, but I do want to keep it that way.
Old Machinist
May 27, 2024
400
431
NE FL
Doesn't sound like an either/or product. I have only used Biobor JF for the last 8 years and haven't had any fuel related issues so I will just stick with that. One cold winter I did add an anti gel additive but I forgot the brand.
Bmyers
May 27, 2019
3,452
4,304
Southern Illinois
1-3 months isn't long term storage. Since you have a snowblower, assuming you live where it is cold enough to gel fuel.
So, you may want to research a few of the forum post on additives and see which one will meet your need.
I have used the Biobor JF, about twice a year to treat the tractors that set to make sure we don't start growing unwanted critters.
3,461
My experience with Biobor JF began in 1980 when I became chief pilot of a corporation that owned jet-powered aircraft. As chief pilot I was also charged with the oversight of the maintenance department of the fleet.
The jets we operated were subject to regular X-ray inspections for corrosion, especially of the lower wing-skins which not only served double-duty as the bottom of the fuel tanks, but also were primary structural strength of the wing. (Imagine that the wing will “bend” upwards in-flight and the lower wing skins became stressed in tension while resisting that wing bending moment..) The tolerances for corrosion-damage were stringent, and repair was breath-takingly expensive.
Airplanes ascend from the humid lower-atmosphere up into and above the troposphere where the outside air temp was commonly -50 degrees F. The fuel becomes refrigerated and is often below Zero-F before descent. Fuel being consumed during the flight, (measured in thousands-of-pounds-per-hour) creating huge air-space in the fuel tanks (known as “ullage”) …now the airplane descends down into the humid lower-levels…and while consuming fuel the humid air (along with the fungal/bacterial spores it contains) enters the vented tanks as the fuel is consumed.
This humid, infected air introduces moisture into a cold wing. Condensation will form on the inside surfaces of the wing, runs down into the tanks, and …water being heavier than fuel, sinks to the bottom of the tanks. The bacteria/fungus spores germinate in the water which settled at the tank-bottom…and consume the fuel as “food”. Their body—wastes create a “mat” of slimey, congealed mass which not only blocks filters but is also acidic and corrodes the tank bottoms that are part of the strength of that wing.
Bad Ju-Ju. …(a technical aviation-term). Expensive if you allow it to remain because the X-rays will show the corrosion which must be treated…and, if bad enough, the lower wing skns must undergo expensive repair and/or replacement to restore the required structural strength.
It’s much better to Prevent the damage than to have to repair it. Allowed to advance too far and the entire airplane becomes scrap.
The aircraft manufacturers required a solution that the engine manufacturers would accept…because anything you add to the fuel to fight the biologicals…must also be consumed and burned-up without.damage to the engine OR cause any issues with the engine continuing to operate without loss of reliability.
The FAA and Aircraft Airframe and Aircraft Engine manufacturers approved only a few products for this purpose…and the product our mfr’s universally approved was “Biobor JF”.
There have been comments in these forums that infer it “removes” the problem. It does not.
It PREVENTS the problem.….not only in storage tanks (which also introduce humid air as the fuel is dispensed to the vehicle)….but also, and Primarily in the actual fuel tanks of the vehicles….. It is a biocide that kills and prevents the growth of the harmful bacteria/fungus.
If the “mat” or “mass” of corrosive-wastes are present…they will continue to corrode metal and block filters and injectors. The system must be Cleaned…and then the biocide is used as a PREVENTATIVE.
Biobor JF is approved for Jet Fuels (basically kerosene and wide-cut distillates), rocket fuels, diesel fuels, and other heavy petroleum. (Gasoline is anti-bacterial of it’s own chemistry.).
There are likely other products that perform similarly….but since Biobor JF meets such stringent standards for aviation use…. It is effective, affordable, and readily available.….and because my 45+ year career trusting and using it was with complete success…. I figure it’s good for my diesel fueled equipment.
6,635
GeoHorn, your review makes me want to have some available!!
Mr Haney
L3710, ZD326S
May 23, 2022
310
81
FL
Well that was a great post.
Old Machinist
May 27, 2024
400
431
NE FL
Biobor JF DOES have instructions for contaminated tanks as well as a preventative treatment for clean tanks. Just read the labels and it will explain the different treatment methods.
I'm glad @imarobot brought this up. I have never heard of or looked into the Biobor MD.
Biobor MD looks like it would be a worthwhile additive for todays tractors with diesel particulate filters but doesn't contain a biocide. Too bad they didn't make a one size does all product. I think I will add it to my fuel since I have a DPF tractor now.
Edit: I ordered some MD to add to my storage tank. If it does what it says my regeneration cycles should be further apart. I am averaging 22 hours per cycle right now.
imarobot
Apr 18, 2025
125
50
NH
Yes it was, and interesting facts!
Great to see what is involved in any technology to make it work properly and safely. There's always more to it than what it looks like on the surface.
imnukensc
BX2380
Sep 10, 2015
728
658
Midlands of SC
GeoHorn's post was absolutely topnotch. Having spent over thirty years in the commercial nuclear power industry and adding Biobor JF to every single tanker truckload (as well as a doing a lot of diesel specific chemistry analysis) prior to them being offloaded into the Emergency Diesel Storage Tanks, I couldn't have come close to explaining the benefits of it anywhere near as closely or specifically. Even if you think you don't need it for your tractor's diesel fuel, add it. It's cheap insurance.
