biggest chipper for 48HP MX4800?
trackman23
MX4800
Nov 22, 2023
114
20
NC
I have an MX4800 and am considering getting a chipper for it so I have the option of making mulch with limbs and scrub rather than always burning them. What is the largest chipped I can reasonable run on my 48HP machine and who makes a decent chipper?
Thanks!
Elliott in GA
Mar 10, 2021
822
831
North Georgia
Made in the USA - 9 inch capacity - power feed - 7 year warranty. The correct price is $6,990 - not what is shown in the preview. Is it the largest? I do not know.
I have the smallest MX series (made in USA) chipper (5 inches) for my 19.5 PTO, and it works very well. It has eaten a lot of 3-5 inch 10 foot tall privet and gum trees. I am sure there are other good choices, too.
How big do you need?
GrumpyFarmer
4,385
Good day.
I have a WC68 (woodland mills) that I use with my B and very happy with it…from a size and weight point of view I would not go any bigger on B sized machine.
That being said eventually I will pair it to my MX which I believe to be similar to yours. I honestly think you could go to a WC88 though with your MX.
I looked at Woodmaxx and Woodland mills when I was in the market. I am not sure there is much difference between them.
Do you plan to use for annual clean up or one time clear out? How large of branch or small tree you want to run through it? If the stock is not straight it’s difficult to use the full size of the opening IME. So if you by something that handle 6” you may not realistically be able to run 6” diameter stock through unless it’s really true and ultimately not larger than the opening. If wanting to run really large stuff through, unless you plan to use regular/seasonally I’d rent a stand alone or have a tree service handle it…their commercial stand alone units will eat pretty large stuff up.
good luck
JasonW
563
330
Al
You won’t be limited by HP for a chipper.
I bought a used Wallenstein BX62 beginning of this year for a project clearing a few acres of bamboo. Definitely enough power with my M series.
Mine is direct drive(no belts) to the rotor. It helped to have it at 540 PTO or above with the bamboo or it would like to clog in the chute, mainly the small tops and leaves. But any regular tree limbs that I ran through it, PTO speed even around 400 it ate everything.
5,267
I have a Woodland Mills WC-68 (6” capacity) paired with a L4701. Your MX is a larger framed, heavier tractor but PTO horsepower is similar. (Based on specs I think you may have something like 2 HP more.)
It handles 6” softwood easily (various pines, eastern red cedar, sweet gum, tupelo, etc.). Often have to reduce feed rate for very sappy, gummy stuff such as green pine to keep the discharge chute from plugging with the gummy chips. Variable speed feed is a good thing.
6” hardwood (white oak, hickory, etc.) will slow down after feeding 4’ or so (assuming it’s about 6” for the entire 4’). Pause feed briefly to feed another 4’, repeat until done. IME something that big that doesn’t taper down within a few feet isn’t common so it isn’t a common scenario. 5” and below, will continuous feed with no issue with any species. Personally, I don’t view the brief feed pause at max capacity with hardwood to be a fault. No different than the 12” capacity chipper I used when I worked for a tree service. I do think that indicates it’s pushing the power limits of the tractor so it’s unlikely you’ll get much, if any, more than about 6” capacity in hardwood, possibly a bit more in softwood.
As @GrumpyFarmer pointed out above, as a practical matter it’s easier to feed a 6” limb into a chipper with an 8” capacity feeder than to feed it into a 6” capacity feeder. May make sense to get a 8” chipper knowing you may not have the HP to use all 8” of that capacity, but will get something easier to feed bigger stuff understanding you may be limited to around 6” with hardwood and more like 7” in softwood. YMMV…
5,267
Technically 39-40.5 according to the AI search!
That raises an interesting question. when implement manufacturer specify horsepower range are they referring to the PTO power or the power of the machine?
PTO.
JasonW
563
330
Al
I would say PTO if the implement is PTO powered.
Back in the day you had drawbar HP rating which is pulling power. You can have 100 engine HP but it’s no good if you can’t get it to the ground.
Or some manufactures that make a utility sized tractor with 35pto hp and the owners can’t run a rotary cutter large enough to cover the tire tracks.
9,429
Do you have a DT or an HST?
