L3540 with the L765 FEL and the BH92 backhoe connected through the remote hydraulic quick disconnect point on back. I plug in my hyd. lines and use a strap to keep the remote hyd. control next to the tractor seat pulled forward to send hyd. fluid back to the backhoe.
My hydraulic fluid is very clean, the filters (and presumably the fluid) changed only about 150 hours ago. I am meticulous in making sure quick connectors have been wiped clean prior to use. I even bought the boots for both ends of each connector and always use them when the backhoe is not installed.
I bought my tractor (1st time owner) about 2 years ago. The backhoe was a nearly new one added on by the dealer at my request. I never had any problem with the backhoe controls until after I reinstalled it after using my mower. That's when this showed up the 1st time.
After calling the dealer, they said to bleed the hyd. connectors by bumping both hoses several times until the pressure was gone. I did and it fixed it.
Several months later, after the 2nd time reinstalling after using the mower, the same thing has happened. Bumped and got it working again BUT noticed that one stabilizer leg control was still to move the handle to make the leg raise up. I worked it back and forth numerous times and it got better. I used the backhoe for several hours.
Now, after sitting 2 weeks, I have the same problem with the same stabilizer control. This is the only one that has ever given me problems. However, this time, after getting it to move fairly well, it was still stiff to move upwards (which pushes the valve downwards in the body), it did not get better. It immediately only got worse. This time the handle would not push as far as the other stabilizer leg control anytime during working the controls over. The control finally got where it would no longer let me push it towards the up direction.
The control will move the leg downward and the motion of moving it off center towards the down direction feels smooth and just like the other leg control. Only the up motion of the control will no longer budge off of center. The linkage appears fully intact, nothing missing or bent and the same as the other leg.
I took the control panel off the backhoe and identified the valve body as a Nabtesco 213256-01, N11 0065.
Help me on what to do next. I am way out from a dealer and would like to handle this myself. I'm a fairly good mechanic.
Also, please advise where I might get a repair manual on the backhoe.
Any help is appreciated.
Thanks.
Thanks.
