BH77 pin issue
diesellucy
burton oh
I recently purchased a BH77 for my L3901. I have 1 pine that barely takes grease. A few pumps and I can not get anymore in I took the zerk out it is good. I took the pin out and it appear that when I grease it that grease comes out of the little hole in the center. I can not get grease down to the far end. I s the hole supposed to gall all the way and another hole drilled in the far end. My dealer is clueless and dosen't want to get me a new pin. Has anyone else had this issue
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
I have not had that issue on mine, but I have a zerk that is a pain on my zero turn mower that does not want to take grease easily. I assume the joint is just tight on my mower and maybe that is your issue.
Have you tried to grease the pin with the backhoe articulated in a different position? Sometimes that can help.
bbxlr8
Mar 29, 2021
391
251
Eastern PA
There is a known issue with some of them (mostly lower) being painted over from the factory initially, but you indicate the zerk is not the problem.
I would try a different position per above or perhaps resting in down to take the weight off if it is one out on the arm. Which position is it that is a problem?
