This has me stumped. I have done everything required in order to remove the BF300A loader from my B8200 tractor. The problem is that the left side tower will not come out of the base. The wedge pins are removed from both sides, as well as the L bolts from the front frame. The right side tower moves up as expected when the bucket is curled back onto the two bars that attach to either side of the bucket, but the left side will not budge even a smidgen. I even hooked my cherry picker shop hoist to the loader arm by the tower and it actually lifted the left side of the tractor off the ground, but the tower is still stuck in the base. For the life of me, I cannot understand how this can be so, seeing how the base of the tower is designed as a wedge to fit down into the base. If I didn't know better, I would think it must be welded in there, but that's not the case. Has anyone had this issue? Any suggestions how to get it freed up? I can't believe that rust and corrosion could hold it that tightly.
Any help appreciated.
Thanks.
- Lyle
Thanks.
- Lyle
