Best Way to Drain Mower Tank?
Mr Haney
L3710, ZD326S
May 23, 2022
293
78
FL
My ZD326 appears to have crud in the left tank or the lines that go to and from it.
It's hard to get a siphon to the bottom. Is there some clever way to drain it?
I was thinking I would detach the return line and pump it out that way, but the fuel would have to go through both filters to get to the return line, and it seems like a bad idea to run more crud through.
I have one of those Harbor Freight oil suckers for car engines. The tube is fairly rigid. Maybe it will go into the bottom of the tank.
Maybe I should nlow the lines out before messing with the tank. For all I know there is a wad of crud stuck in one of them.
The manual says to replace the lines every so often. I wonder if anyone has ever actually done that.
They look perfectly sound.
Mr Haney
L3710, ZD326S
May 23, 2022
293
78
FL
Wouldn't you know it? I just ran the mower for a while, and it never bogged. Maybe Clear-Diesel ate the booger that was blocking the fuel.
Mr Haney
L3710, ZD326S
May 23, 2022
293
78
FL
Mowed the yard today, and the left tank eventually quit. I guess the diesel boogers were too much for Clear-Diesel.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
115
42
NH
Never heard of Clear-Diesel, how is it different from off road diesel?
Mr Haney
L3710, ZD326S
May 23, 2022
293
78
FL
whitetiger
Nov 20, 2011
3,181
1,602
Kansas City, KS
Only seven bolts are holding the operator's platform on, three more holding the fender on. That reveals the fuel tank, which is secured with two bolts. There are 3 cushions under the tank, two under the front and one under the rear.
It can easily be removed and cleaned out.
Removing the hose from the inlet of the front fuel filter allows air to be blown backwards through the hoses to ensure they are clear. (With the selector valve turned to the LH tank, of course.)
Mr Haney
L3710, ZD326S
May 23, 2022
293
78
FL
I am thinking this over.
Crud in the lines can't be the problem, because most of the time, the flow is good. If the lines were obstructed, the mower would always be slow. That means there has to be crud in the fuel itself.
The fuel itself must be the issue.
Based on my experience with 8V71's and Racors in a boat, I believe clear diesel is good diesel. By that I mean I might as well see if I can save whatever clean diesel is in the tank and throw out the water and crud I find, but for $15 worth of diesel, I shouldn't try very hard.
whitetiger
Nov 20, 2011
3,181
1,602
Kansas City, KS
If you remove and clean the fuel tank, it is foolish not to blow out the supply line while you're there.:)
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
181
285
Grayling, MI.
Interesting. Even though my BX is brand new right now, over time I may have similar things like you described start happening. I may look into getting Diesel Kleen +Cetane Boost. You put it in every time you fill the tank. Or would ya'll not recommend doing that. I always keep my tank full and this may not be needed.
5,671
It's probably not so much how full the tank is but how OLD the fuel is.
In my case though , fuel was fine, there was an 'obstruction' in the exit spigot.....
Mr Haney
L3710, ZD326S
May 23, 2022
293
78
FL
This could be Obama or even late Bush fuel. I have no idea.
My impression is that the owner was too lazy to use both tanks, so he ran the right one dry over and over.
If so, it suggests he didn't use it all that often. No intelligent person wants to fill one tank over and over when he can fill two tanks half as often.
